Engine Cooling problem
1998 Dodge Durango V8 Four Wheel Drive Automatic
I need to replace the freeze plug that is behind pass. side motor mount on 318 motor. To pull the motor mount off do I need to also drop the front differential like the repair manual says, or can the motor mount and engine support bracket be removed without removing the front axle assembly.
Nov 9, 2008 at 8:43 PM
