engine stalling
DODGE DAYTONA
84DAYTONATURBOZ
1984 dodge Daytona Turbo z, mileage 93,695. 5spd. problem, when i slow down to approach a stop sign or make a turn the engine will stall on me unless i keep giving it gas. typically only happens when clutch is in but has happened while in neutral.
Sep 8, 2007 at 7:30 PM
Hi:
The most common problem on this vehicle is a vacuum leak. Check closely for broken or damaged hoses. Also, listen for a hissing that could indicate a leak.
Let me know what you find.
Mar 11, 2009 at 9:11 PM
