2001 Dodge Daytona horn
2001 DODGE DAYTONA
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
HARRY HARRINGTON
The horn stopped working so i checked the fuse which is ok. the horn does work with the alarm system. Is there anything else that i should check before i end up taking it to a repair shop.
Nov 12, 2009 at 5:09 PM
CH112063
  • 1,320 POSTS
No, not unless the switch is bad. The horn had its connection through a clockspring. I wouldn't recommend replacing one unless you've done one. Its good, you have checked what you could.k
Dec 21, 2009 at 9:05 PM
