2000 Dodge Daytona codes and results
2000 DODGE DAYTONA
150,000 MILES • V8 • 4WD • AUTOMATIC
DAMDOGES
1st code reading said injectors 27 circut open, replaced all injectors, p0202 & p0207
2nd leak detection pump pressure switch or mechinical default, replaced pressure as per Dodge using that code, cleared light as soon as engine fired new light same code. they did not have the intank fuel filter so it is ordered. will the poor/ plugged/ bad filter cause this same fault is is there another.
Runs well afetr warming but will idle high and fluxuate at in gear stop or when in park
Thanks,
Mar 3, 2008 at 12:13 AM
Hi:
A bad filter can limit the fuel pressure and cause the injectors problems.
Mar 11, 2009 at 8:52 PM
