Electrical problem
1989 Dodge Daytona 4 cyl Automatic 90235 miles
"I have a dodge daytona 1989 turbo 2.5. the speed idle sensor not work. when I star the car, the tacomether goes to 2,500 rpm, and does not drop, does not maintain the minimum (1000 rpm or 950 rpm), the car is automatic. The two windings of the 'motor' are 1-4 pins and 2-3 pins and I check the continuity in measure between the pairs of pins and this is OK. The connections are to pins 19-18 and 17-20 respectively of the engine controller 60-way plug I check the continuity to the speed idle motor and this is OK. I clean al the trhotle body. after that I make this the speed idle motor NOT WORK. what I do? I wait your answer thanks!
Jan 20, 2010 at 8:22 PM
