1989 Dodge Daytona SPARK PLUG MISFIRE
1989 DODGE DAYTONA
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
JDODGE89
i HAVE JUST REPLACED THE PRESSURE RELIEF VALVE DUE TO IT BUSTING - ?. WHEN I GO THIS DONE I NOTICED A MISFIRE. I DISCONNECTED THE PLUG WIRES 1 AT A TIME & WHEN I GOT TO THE LAST ONE, IT STOPPED. I HAVE REPLACED THE PLUG AND IT STILL DOES THE SAME THING. WHAT ELSE SHOULD I BE LOOKING AT THAT MAY BE CAUSING THIS PROBLEM?
Aug 11, 2009 at 3:10 PM
CH112063
  • 1,320 POSTS
I hope you mean when I got to the last cylinder there was no difference, it still had a misfire, maybe that injector wire is not connected or working for that cylinder or there is a compression problem with that cylinder. If 4 cylinders are not working evenly and it gets worse as you pull the plug than that cylinder is not the problem, if one just runs the same whether its has a plug wire or not then that cylinder is the problem cylinder. Spark, injector(single point injection) compression in that cylinder or a bad vacuum leak at that cylinder will cause a partial or total loss of power in that cylinder.
Sep 11, 2009 at 3:06 PM
