1972 Dodge Dart Vacuum
1972 DODGE DART
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
72ETHEL
Hello, My name is Holland. My husband and I own a 1972 Dodge Dart Swinger. We had the engine rebuilt about half a year ago. The car could drive the mountain fine, and well. All of a sudden, it could barely make it up a hill. We had the carberator rebuilt and a new starter installed about three days ago. My husband put in new spark plugs and checked the distributor. He said that when he takes the vacuum off, where it is connected to the engine or something, the car works fine. It goes up hills. He said he can't leave it that way because dirt and grime would get clogged and screw everything we worked so hard for, up. So my basic question is are there any manuals to help my husband check the vacuum lines or any advice? we are broke for the next month and are trying to get this fixed ourselves. To get the kids to school. Thanks very much.
Sep 10, 2009 at 9:39 PM
CH112063
  • 1,320 POSTS
Your husband needs to identify the vacuum source and what it is used for. If the distributor advance is getting manifold vacuum and it should be getting ported vacuum the carb. hoses could be mixed up and vice-versa. The only thing that makes a car run better with a vacuum leak is a car that is running with too much gas being given to it from a carb. circuit failure, a distributer advance problem, or an evaporative emissions(vapor canister) problem. I would have the carb. rebuild rechecked, it may have failed or been improperly re-installed. That is the bottom line on this problem. ok if you were my neighbor, it would be done already. you have touched my heart. ok sorry
Sep 27, 2009 at 2:53 PM
