dodge dakota, abs and brake light stuck on
DODGE DAKOTA
KINGJ23
i have a 99 dodge dakota 4x4 v6 with 160000, km, all of a sudden the abs and brake light, from the foot brake, wont turn off, i now there connected somehow they came on at the same time, how do i turn them off, and yes the foot brake is off, plus the speedometer only works above 60 kmh, if its the speed sensor where is it and how do i fix it
Sep 25, 2007 at 11:51 AM
SEBASTIAN
[quote:da4e29d1c1="kingj23"]i have a 99 dodge dakota 4x4 v6 with 160000, km, all of a sudden the abs and brake light, from the foot brake, wont turn off, i now there connected somehow they came on at the same time, how do i turn them off, and yes the foot brake is off, plus the speedometer only works above 60 kmh, if its the speed sensor where is it and how do i fix it[/quote:da4e29d1c1]yes it is the speed sensor it is on transfer case
Oct 9, 2007 at 9:14 PM
SCHOOLBOY
have you used a scan tool to check for codes? I have seen the rear abs sensor in the rear axle cause both light come on.
Oct 24, 2007 at 8:10 PM
DABOOCRU02
  • 18 POSTS
I had the very same problem and i took the advice that was given to you and replaced the abs speed sensor. It fixed the problem for me immediately. Thank you so much for the help.
Oct 24, 2007 at 8:27 PM
WVMINER
[quote:281b6e67d5="kingj23"]i have a 99 dodge dakota 4x4 v6 with 160000, km, all of a sudden the abs and brake light, from the foot brake, wont turn off, i now there connected somehow they came on at the same time, how do i turn them off, and yes the foot brake is off, plus the speedometer only works above 60 kmh, if its the speed sensor where is it and how do i fix it[/quote:281b6e67d5]Have you checked the brake fluid level? Low level will trigger the lights.
Oct 25, 2007 at 8:04 AM
