Good evening,
It sounds like one of the axles are not locking in.
Is there any damage to the axle? Is it turning?
C205F - Front Axle
DESCRIPTION
The C205F axle consists of an aluminum center section with an axle tube extending from one side. The tube is pressed into the differential housing. The power is transferred from the axle through two constant velocity (C/V) drive shafts to the wheel hubs. The drive shafts are identical and interchangeable.
The differential case is a one-piece design. The differential pinion mate shaft is retained with a rollpin. Differential bearing preload and ring gear backlash is adjusted by the use of select shims. The shims are located between the differential bearing cups and the axle housing. Pinion bearing preload is set and maintained by the use of a collapsible spacer. The differential cover provides a means for inspection and service.
The axle has the assembly date and gear ratio listed on a tag. The tag is attached to the housing cover by a cover bolt.
OPERATION
The axle receives power from the transfer case through the front propeller shaft. The front propeller shaft is connected to the pinion gear, which rotates the differential through the gear mesh with the ring gear bolted to the differential case. The engine power is transmitted to the axle shafts through the pinion mate and side gears. The side gears are splined to the axle shafts.
Apr 14, 2021 at 6:14 PM
(Merged)
