2006 Dodge Dakota changing hub assembly
2006 DODGE DAKOTA
MONE7801
2006 Dodge Dakota 6 cyl Two Wheel Drive Automatic
how do you change out front hub assembly on a dodge dakota
Feb 2, 2009 at 5:43 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:24eb0f7818="mone7801"]2006 Dodge Dakota 6 cyl Two Wheel Drive Automatic
how do you change out front hub assembly on a dodge dakota[/quote:24eb0f7818]
It is fairly simple...
Remove the front wheel, brake caliper then brake rotor.
Next you will need to remove the bolts holding the hub assembly on. If has ABS disconnect it and make note of position.
You will have to pry the old one out, but should be easy as long as you pry from different points.
Before putting new hub in make sure you clean the surface from rust and debri.
If has ABS make sure to align same way as old hub.
Feb 2, 2009 at 5:54 PM
