2005 Dodge Dakota squeak
2005 DODGE DAKOTA
77,000 MILES • V8 • 4WD • AUTOMATIC
BSCHUCK
Truck Squeaks when going over bumps nothing appears to be loose or worn driving me nuts
Sep 26, 2010 at 3:59 PM
INFAMOUSWB
  • 6 POSTS
I have the same thing. I have an 05 Dakota SLT 4x4 with the V8. It squeaks on bumps & turns. I have tried to look at it and can't narrow it down to an exact part. It sounds like the bottom of the shock/strut mount.
Here's what I have found via Dodge Forum.com and Dodge Dakotas.com ... look at the rubber bushings. This seems to be a common theme with our Dodge Dakotas. Use mobil 1 synthetic grease and the squeak will probably go away. If not, then start looking at ball joints, both lower & upper.
If you aren't mechanically inclined, take it to a front end specialist. You can take it to a Dodge dealer but I discovered in some of the posts that they have been stumped by this problem. Hope this helps you. I'm going to try these recommendations as well.
Sep 27, 2010 at 1:20 PM
