Heater/AC fan does not work
2005 DODGE DAKOTA
65,000 MILES • V8 • 4WD • AUTOMATIC
MARK JACOBS
My 05 dodge dakota heat/AC fan just stopped working. The fan was working fine with the AC, I stopped to put gas in the truck and when I got back in the fan no longer worked. There was no noise as if the fan had burnt out. All the fuses under the hood and dash seem to be OK. What could be the problem?
Jun 23, 2009 at 2:16 PM
It sound like he blower motor when out but to be sure here isa guide to help you see whats going on.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Jun 23, 2009 at 2:18 PM
OIDAVEY
  • 0 POST
It was the blower motor on my truck I had to get a new one cost me $132.00 all fixed!
Apr 16, 2019 at 2:21 PM
PJPLYMOUTH
The blower works on high only. Is something loose or do I have to replace the whole switch? How do I replace it? Take the dash out or........?
Dec 1, 2020 at 12:11 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
it sounds like the speed control resistor is out here is the location so you can check it out. It is right next to the blower motor. Check out the diagrams (Below). Please let us know what happens.
DPERDUE00
my heater fan has quit working. 1st the lower speeds quit then the high speed quit. what to do
BLUELIGHTNIN6
  • 16,542 POSTS
check fuses and blower motor relay. if both OK suspect faulty blower motor resistor
SHORTCHANGE15401
My blower for the climate control has quit working. I took out the blower motor and tested it with the battery and it works so the problem must be somewhere else. I also checked the fuses and they are ok. Where should I look next and how do I test it?
Most common problem is the blower motor resister. That is where I would check next.
