brake light fuse?
2004 DODGE DAKOTA
40,000 MILES • V8 • 4WD • AUTOMATIC
GREG2004
I've got an '04 Dakota V8 Sport, and while pulling a trailer, I lost all signals, hazards, and brake lights. The fuses are all good in the cab, and I tried a new flasher, but it made no difference. I can hear the flasher click once when I flip the signal or hazards on, but it only clicks once and nothing lights up. Everything else electronic seems fine. Any suggestions? Thanks,
Jan 9, 2008 at 8:30 PM
BMRFIXIT
  • 19,053 POSTS
[quote:8d55cac739="Greg2004"]2004 Dodge Dakota V8 Four Wheel Drive Automatic 40000 miles
I've got an '04 Dakota V8 Sport, and while pulling a trailer, I lost all signals, hazards, and brake lights. The fuses are all good in the cab, and I tried a new flasher, but it made no difference. I can hear the flasher click once when I flip the signal or hazards on, but it only clicks once and nothing lights up. Everything else electronic seems fine. Any suggestions? Thanks,[/quote:8d55cac739]
check under hood relay box fuses
Jan 30, 2019 at 2:43 PM
BOAT BOY
I looked at both fuse boxes, there is nothing labeled stop lights or brake lights. The brake lights are out, bulbs are good, but can't find fuse.
Jun 8, 2020 at 5:57 PM (Merged)
CAR-MAN145
  • 321 POSTS
The brake light Fuse #1 20 amp in the fuse panel here is a guide to help test the fuse and the fuse location below.
TAYLORA89
hi. i got a 1995 dodge dakota 2wd with 156,000 miles on it. my abs and emergency brake lights have come on, and wont go off but tonight i notcied my brake lights will not come on yet i still have hazard, turn signals and reverse lights. is it the fuse or a bulb. thank you for reading
Jun 8, 2020 at 5:58 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
[quote:7870ea2239="taylora89"]Electrical problem
1995 Dodge Dakota 6 cyl Two Wheel Drive Automatic 156000 miles
hi. i got a 1995 dodge dakota 2wd with 156,000 miles on it. my abs and emergency brake lights have come on, and wont go off but tonight i notcied my brake lights will not come on yet i still have hazard, turn signals and reverse lights. is it the fuse or a bulb. thank you for reading[/quote:7870ea2239]
brake light switch also is part of the ABS system
so you should start checking fuses and also check the switch located at the brake padel
good luck
let me know
SCUBAQUAD
Electrical problem
1994 Dodge Dakota 6 cyl Four Wheel Drive Manual
ihave lost turn signals ,hazzards, and brake lights tried fuses and bulbs , now what?
Check and test the multifunction switch on steering column all those circuits goes thru this switch.
