2004 Dodge Dakota pump
2004 DODGE DAKOTA
REMI
Steering problem
2004 Dodge Dakota V8 Four Wheel Drive Automatic 55000k miles
i developed a leak on the pump and replaced it with a remanufactered pump from chrysler, pump was very noisy(whining) after and was leaking on shaft after 1 mth of limited use. replaced it with another reman. pump and after a short time it was leaking again, on the pressure line inlet, replaced again today by dealer and although not leaking yet it is very whinny and after a few minutes driving there is pressure in the reservoir when i undo the cap the pressure is released. Can there be problems with the rack that would cause this?
tks
remi
Nov 20, 2009 at 4:58 AM
The rack wouldn't cause this. Was the system properly bled? Are there air bubbles in the fluid?
Nov 20, 2009 at 10:51 PM
