truck starts to run hot and heater is blowing out cold air. replaced thermostat about 2 months ago. this does not happen all the time.
Jan 5, 2009 at 1:27 PM
CERTIFIED EXPERT
Hi:
Have you had the radiator and the heater core flushed?
Jan 6, 2009 at 1:40 PM
QCQUEEN
MEMBER
no
Jan 7, 2009 at 2:47 PM
CERTIFIED EXPERT
Hi:
That is where I would start. If you replaced the t-stat, something must be blocking the coolant from circulating. At least have it checked by a mechanic to see if that appears to be the problem or check the radiator for circulation yourself. If you need directions, let me know.
