2003 Dodge Dakota truck running hot
2003 DODGE DAKOTA
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
QCQUEEN
truck starts to run hot and heater is blowing out cold air. replaced thermostat about 2 months ago. this does not happen all the time.
Jan 5, 2009 at 1:27 PM
Hi:
Have you had the radiator and the heater core flushed?
Jan 6, 2009 at 1:40 PM
QCQUEEN
no
Jan 7, 2009 at 2:47 PM
Hi:
That is where I would start. If you replaced the t-stat, something must be blocking the coolant from circulating. At least have it checked by a mechanic to see if that appears to be the problem or check the radiator for circulation yourself. If you need directions, let me know.
Let me know how this works for you.
Jan 7, 2009 at 3:00 PM
