I suspect you have two issues now. First was the interlock was not releasing which is why you could not shift out of park. However, now the cable is most likely broken or come off the transmission.
So I would just make plans to replace the cable with the attached process but you can start with inspecting it and just make sure it is broken or if it is unattached.
Let us know if you need more info. Thanks
Nov 23, 2020 at 2:53 PM
