[quote:0bcb815733="Jacobandnickolas"]Peter:
Just for the heck of it, see if the drain is plugged. Under the hood on the passanger side of the firewall, you will see a black rubber tube that points down to nothing. Move it around to see if there is any dirt at the end. THat is where they usually clog from dirt and garbage from the engine and road.
Let me know what you find.
Joe[/quote:0bcb815733]
Thanks so much Joe. I didn't find a rubber tube. What is it connected to? I downloaded a service manual for my Dakota and didn't find a diagram of the condensate drain.
I looked all over and followed every line near the passenger side firewall from the engine top side and jacked the truck up and looked underneath too. I removed a thin metal shield (pie shaped about 8"x8" above the manifold pipe) and found a horizontal hole in the firewall covered by the shield that I could stick a finger and 4" screwdriver into. It did not appear to be blocked. Perhaps the tube is gone?
Any suggestions on where or to what this tube is attached? I remember a mechanic said it was a real bitch to get at the drain. He had the truck on a lift and was poking around from below near the manifold pipe. I left the shield off.
Again thanks for your help. Sorry i'm no mechanic.....Peter
Jan 22, 2010 at 11:15 AM
