PO441 - Evaporative Emission Control System Incorrect Purge Flow
Chances are you have a leak in the EVAP system. Have you had anything done yet?
May 9, 2010 at 4:35 PM
JAZON
MEMBER
I have not done anything. So I should look for a leak? I do smell gas sometimes in my garage. Also the light is now off, for the second time ?!?
Thanks Jazon
May 17, 2010 at 10:21 PM
CERTIFIED EXPERT
Chances are you will not see a leak but rather smell fumes from the system. What I would suggest at this point is to have the system fogged. Basically, they will pump fog into the system and where the leak is, the fog will come out to identify the leak.
