2002 Dodge Dakota Wer passenger side carpets
2002 DODGE DAKOTA
150,000 MILES • V8 • 4WD • MANUAL
DHORN
2002 Dodge dakota 4.7 Liter ,4WD approx 150,000 km .Passenger side carpets drenched with water (not anti freeze)=Water pump ,thermostat recently replaced-Truck is garage kept and has been out of the rain for at least two months (no chance of an external leak) Air conditioning is only rarely used- Coolant reservoir stays full-Please identify leak possibilities and suggested repairs
Sep 15, 2010 at 3:14 PM
I would start by checking the drain for the AC. Even though you don't use it often, it will fill and leak if the drain is plugged.
The drain is on the passanger side of the firewall (under the hood). Usually, the get plugged at the end from dirt and water mixing.
Check that and let me know what you find.
Sep 15, 2010 at 9:00 PM
