2001 i hope this is something simple
2001 DODGE DAKOTA
SHADDOW1973
Drive Train Axles Bearings problem
2001 V8 Two Wheel Drive Automatic 132xxx miles
my 01 dakota has started building pressure in the rear axle housing causing fluid to be blown out. can u plz give some advise on how to correct this problem?
Aug 2, 2008 at 6:04 PM
MERLIN2021
  • 17,250 POSTS
Check the vent on one of the axle tubes, it may be clogged, and make sure it's not overfilled...remove the plug and the fluid should be at the bottom of the hole.
Aug 2, 2008 at 6:12 PM
