2001 Dodge Dakota can't locate noise
2001 DODGE DAKOTA
122,000 MILES • V8 • 4WD • AUTOMATIC
DHIAWATHA
I have a noise that sounds like it is coming from the rear of my truck when turning while backing up. It sounds similar to the tire rubbing something but I know that it is not. I changed the rear brake shoes and the rear u joint seems ok? I am having difficulty in locating exactly where it is coming from?
Nov 23, 2009 at 9:11 PM
CARADIODOC
  • 34,306 POSTS
Strap someone underneath with a stethoscope while you back up!
Well, sure, there might be safer ways to find the noise. One way is to jack up the rear axle and run it in reverse to see if it still makes the noise. If only one wheel turns, it will be normal to hear gear noise from the differential. If you have a locking differential, it should be quiet until you turn while backing up. Even then, at such low speeds, it shouldn't make much noise.
Look at the tail pipe moving when the engine rocks when placed in reverse. Perhaps the muffler is rubbing on the drive shaft. If you still haven't figured it out, mechanics have a tool called a chassis ear. It's 6 microphones clipped onto suspect locations. You drive with a receiver, and switch between the microphones, listening for the loudest one. By moving the mics around, you can zero in on the source of the noise.
caradiodoc
Nov 29, 2009 at 11:52 PM
