2001 Dodge Dakota brakes
2001 DODGE DAKOTA
HOUNDDOGG39
2001 Dodge Dakota 6 cyl Two Wheel Drive Automatic
I would like to know the right way to bleed the brakes after installing master cylinder,,,,just if theres a seaquince or something like that,,,Thanks kevin
Mar 26, 2009 at 10:10 PM
EUGENE123
  • 273 POSTS
to start its easier if you have to people then what you do is have one person pump the brakes up as hard as the pedal will go then have the other person release then bleeder valve after relasing it tighten it back up and repeat process a few time, the bleeder valve is located on on the caliper or if its drum brakes on the back part of the drum brake repeat this several time to make sure all air is out of lines, then check brake fluid to make sure fluid is full
Mar 26, 2009 at 11:10 PM
