2001 Dodge Dakota 4 wheel drive high is not working, but 4
2001 DODGE DAKOTA
12,000 MILES • V8 • 4WD • MANUAL
NATE3131US
I was driving in the mountains in 4 wheel drive when all of the sudden I was in two wheel drive and no longer had 4 wheel. Pulled over and checked 4 low which seems to be working ok. However it will not engage in 4 wheel drive. How do I fix this? What do you think is the problem. If I take it to a mechanic to get it fixed how much will it probably cost me?
Mar 8, 2010 at 9:51 AM
If 4wd lo works, the front axle is working. Is this an electric shift 4wd or does it have the shifter on the floor?
Let me knos.
Mar 8, 2010 at 5:23 PM
NATE3131US
The shifter is electric, the shifter is not on the floor. I have been driving in lots of mud up here in parachute CO. Would that have anything to do with the electric shifter to not function right?
Mar 9, 2010 at 9:46 AM
What I need you to check is the connection / plug to the 4wd actuator on the transfer case. Make sure it is tight, clean, making a good connection, and it is getting power when you shift to 4wd hi.
Mar 9, 2010 at 10:09 PM
