I recently had a check-up done (no work) and they identified the transmission fluid being way too high. I've also recently started noticing the car shakes, when I start driving, until I get to higher speeds (gears) and then it stops after the car warms up. The whole car also rocks when I shift into or out of reverse. I think this is all related to the high transmission fluid, and I'm wondering one does that make sense? And two, does transmission fluid thin out (density changes) as the car warms up, because after driving for a little while, the shaking in lower gears stops. Thanks!
Dec 20, 2008 at 8:29 AM
