2000 Dodge Dakota runs rough, ses lamp illuminated
2000 DODGE DAKOTA
40,231 MILES • V8 • 4WD • AUTOMATIC
SEABEECM1
runs rough, does not miss/skip under load. codes for lean exh and injector 6 driver ckt. I replaced inj. 6 because there is pulse to the injector, but I still get a rough idle, rich exh. smell and lean exh. code with inj. 6 driver code. Power braking does not result in engine miss. rough at idle and reduced power are noted.I sprayed water around the intake and checked for a vac. leak but didnt find one.[img:0472c4e828]http://www.2carpros.com/forum/automotive_pictures/191684_02_Sun_Rise_1_1.jpg[/img:0472c4e828]
May 18, 2008 at 3:28 PM
LEGITIMATE007
  • 5,121 POSTS
beautiful pic. sounds like you have a vacuum leak . check for vacuum leaks or cracks in vacuum hoses.
May 18, 2008 at 3:47 PM
