Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Dakota
Ignition
Coil
Replace/Remove
2000 Dodge Dakota Replace pick-up coil on Distributor
2000 DODGE DAKOTA
96,000 MILES • 6 CYL • 2WD • MANUAL
BOWMJRRY08
MEMBER
1 POST
FOLLOW
How to replace the pick-up coil on the distributor? Do I need to remove the Distributor from the Block or can I replace it without removing?
Jan 29, 2010 at 3:28 PM
CERTIFIED EXPERT
Some can be done from the top without removal. Check to see. If it needs removed, you will need to remove the gear to get the shaft out.
Feb 4, 2010 at 10:18 AM
