I recently replaced my power steering pump since the seals were bad and it was leaking out and spraying the engine compartment with fluid. After replacement with a remanufactured pump it does not leak but whines. I am wondering if there is a filter in the reservoir that would be starving the replaced pump. I can't find a place to just get a reservoir unless I replace the pump again with a dealer pump and reservoir. Could this be the problem or is it something else. Could I have a bad reman. pump? I did bleed the system of air.
Nov 3, 2008 at 9:35 AM
