2000 Dodge Dakota Oil Pressure Guage
2000 DODGE DAKOTA
12,000 MILES • V8 • 2WD • AUTOMATIC
ACJCCP
What is the normal oil pressure fluctuation of an engine? Without specific numbers, is the pressure supposed to increase as the engine RPM increases? Falls back to a minimum on idling?
Jun 23, 2010 at 11:25 AM
At an idle, it shouldn't go below 10 PSI. I would say it shouldn't exceed 80 PSI. Also, it is normal for it to drop lower at an idle. How low is yours getting? Are you hearing any ticking or knocking from the engine?
Jun 23, 2010 at 10:27 PM
Finally, keep in mind, if you are not hearing any noise from the engine, it could be something as simple as the oil sending unit which is an inexpensive part that sends the signal to the gauge as to how much pressure there is. It isn't uncommon for them to go bad.
Jun 23, 2010 at 10:29 PM
ACJCCP
Thanks Joe! No unusual sounds or performance, just noticed the oil pressure guage changing with RPM. It may have been doing this all along and I just noticed. Getting conscious of my engine's mileage, 120K, and just over sensitive. Don't know the exact pressure, reading off the car's dash guage. Really appreciate your help.
Jun 24, 2010 at 6:09 AM
I'm glad to help. Honestly, I have an older Dakota with 220K on it. It's the V6 and runs every day. If you keep your oil changed and filters clean, that engine should run to 300K. The only weakness with the truck is the transmission.
Jun 25, 2010 at 12:52 AM
