2000 Dodge Dakota Diagnose squeaking and vibration problem
2000 DODGE DAKOTA
100,000 MILES • V8 • 4WD • AUTOMATIC
IRONHAYDEN
My 2000 Dodge Dakota 4.7L V8 4x4 has a squeak under the vehicle when I start and at low speeds. At faster speeds (30-55mph) it has a worsening vibration.
Is this a failing u-joint? If so, how do I know if its front or rear U-joint?
Could it be a transmission problem? Hopefully not.
May 1, 2009 at 11:47 AM
I doubt it's the transmission. If you bounce the front of the truck, does it squeak? Also, have you had tire balance checked. As far as front or rear, the best I can tell you is to try to listen. Check for play in the u-joints.
Let me know what you find.
May 2, 2009 at 1:15 PM
