2000 Dodge Dakota Computer? Electrical? Frustration!!!!!!
2000 DODGE DAKOTA
179,495 MILES • V8 • 4WD • AUTOMATIC
MATTRICK1978
The problems that are occuring with this vehical started without any warning! The day stuff went haywire i had started and stopped the truck 7 times. I went to start it and didn't have enough power to make the door dinger ding so i jump started the truck. (at this point there hasn't been any check engine lights at all) Once the truck was running for about 5 minutes the volt meter on the dash went up to 18 and all the lights were flickering so i figured voltage regulator. I replaced the alternator and the the volt gauge still went up to 18. after talking with several mechanics i was told that the voltage regulator is in the computer in that truck. I unhooked the positive battery cable while the engine was running and immediately the volt meter went back to 14. I drove the truck about 10 miles home with the cable unhooked and the volt meter went up to 18 about 5 miles into the trip. I replaced the computer. When I jump started the truck and with a new computer and alternator this was the first time the check engine light came on and it was only running on 7 cylinders. The volt gauge is now at 14 (normal) and the lights are no longer flickering. At this point the engine had been running about 5 minutes and I began to smell a electric fire type smell so i shut it off and discovered that the coil pack on the front right cylinder was melted and almost caught fire. I am very puzzled about whats wrong. I have kept very good care of the truck and always keep up on routine maintenance. I no I need to get a diagnosis done to see what code are in the computer but im hoping to get some answers or suggestions before i spend anymore$. Please HELP! To expidite a response please feel free to call or text me at 740-243-5362
Mar 12, 2010 at 1:37 PM
CARADIODOC
  • 34,306 POSTS
You have caused an unknown number of problems by running it with the battery disconnected. That was a simple test uneducated mechanics did many years ago when they didn't understand how charging systems worked.
The battery is an important part of the voltage regulating system. The alternator puts out three phases of pulsing voltages. The battery smoothes those pulses out to a steady voltage which the regulator watches. Without the battery, the regulator will try to respond to the dips in the output voltage from the alternator. A dirty or loose battery cable could have started this. When the alternator voltage dropped momentarily to around 13.0 volts, the regulator commanded an increase in output. 18.0 volts or higher is a very likely outcome.
Computers are not very tolerant of incorrect supply voltages so there's no telling what has been damaged. The place to start is with the battery cable connections. Be sure they're clean and tight, and do not run the engine with the battery disonnected.
caradiodoc
Mar 12, 2010 at 1:55 PM
CARADIODOC
  • 34,306 POSTS
It's hard to say definitely if a burned up coil was caused by the high system voltage. Logic would dictate other damage should have occurred too. Another possibility is the coil was getting ready to fail, and the high voltage just hurried things up a little.
Just to clarify, is it the ignition coil that burned up or some other component? Eight coils-on-plug are only used on the 4.7L engine, so I'm guessing that's what you have.
Once the Check Engine light turned on, there was a diagnostic fault code stored in the Engine Computer's memory. There are two possible codes. The computer can detect incorrect current going to one coil and set a code for that, or it can detect a specific cylinder misfire. There might also be a code for "field current not switching properly". That would be for the charging system problem.
There are a number of things that can cause the charging voltage to go to 18 volts. A shorted voltage regulator inside the Engine Computer is one possibility, but there are so many safeguards built in that it doesn't happen very often. Since the problem occurred again with the replacement computer, the voltage regulator can be ruled out.
In very rare instances one of the small terminals on the back of the alternator can become grounded, but that won't happen on its own. It would happen when replacing the alternator but would also be very unusual.
The most likely suspect is the dark green wire between the alternator and Engine Computer becoming shorted to ground. That will cause the alternator to charge wide-open. One thing that suggests this might not be the problem here is the voltage only went to 18 volts, (or was that the assumption because that's the highest the gauge reads?). Grounding this wire is a test mechanics use to determine if the cause of a no-charge condition is the fault of the alternator or the regulator. When grounding this wire, system voltage typically goes to 16 - 18 volts at idle, but it is very important that if it does, you must not raise engine speed. At higher rpm, alternators can reach as high as 35 volts. On older cars, that would pop any light bulbs that were turned on. On newer cars and trucks, various computers would be damaged before the voltage got that high. By driving the truck for ten miles with high system voltage, regardless if the battery was disconnected or not, things should have been "exploding".
The fact more things weren't damaged suggests system voltage didn't go catastrophically high. That would lead to another possibility; a break in the system voltage sensing wire going to the Engine Computer. If it's broken or corroded, there's no telling what voltage that wire will "float" to and be seen by the regulator.
Double-check the battery cables and connections. Besides the overcharging, loose or corroded cables will cause the original failure to crank. The only other cause would be a discharged battery which will not occur if overcharging is the only problem.
If the system continues to intermittently overcharge, connect a wire to the alternator that you can run inside the truck to monitor with a cheap digital voltmeter while you're driving. Both small terminals will only have voltage for one second after turning on the ignition switch, then they will go to 0 volts. The voltage will come back when the engine is rotating, (cranking or running). One terminal on the alternator will have full battery voltage. You must connect to the other one. This terminal must never have 0 volts, but the lower it is, the harder the alternator is working.
When the problem occurs, observe the voltage on that wire. 0 volts indicates that wire is being grounded somewhere. Look for electrical harnesses drapped over sharp metal brackets or laying on hot exhaust parts.
If you find around 4.0 volts on the wire, suspect a problem with the voltage sensing wire. The most the voltage regulator can do is draw this wire down to around 4.0 volts.
caradiodoc
Mar 12, 2010 at 8:06 PM
JON WARNER
@mattrick1978, curious, did you locate the source of your issue? I have a 2000 with 167,000 mi. (4.7L) and am currently experiencing a similar issue. My meter intermittently drops to zero (triggering the "check gages"), after lingering at (maybe) 12. I cleaned the corroded batter terminals, which initially appeared to solve the problem, but now, if I shut it off for short period (run in to get milk, etc.), then restart it the issue occurs again. Longer I let it sit, restart, appears to works normal... ???
Dec 23, 2010 at 4:48 AM
SHARON MARIE PARKER
My nephew's truck ran fine from Friday to Sunday, then it wouldn't start up, cleaned off the terminals and wires, popped open the fuse box under the hood, noticed a wire loose small and skinny looking. Can't figure out what it goes to, got a jump start. It ran fine then Monday night, all my dash lights went dim then truck wouldn't start at all. Had to jump start it again basically had to two foot it home so it wouldn't stall out, waited 10 min then wouldn't crank over at all.nothing help please trying to figure it out
Dec 4, 2018 at 5:34 PM
DANNY L
  • 5,648 POSTS
Hello,I'm Danny
You've attached your question to one that is years old.You need to ask a new question and be sure to include your vehicle information.Hope this helps and thanks for using 2CarPros.
Danny-
Dec 7, 2018 at 5:45 PM
