2000 Dodge Dakota 4.7L
2000 DODGE DAKOTA
KRASH
  • 4 POSTS
I just put a new engine in this truck and it will not start. I have replaced the cam position sensor and it still will not start. I pulled a P1391 code and the book dosent even show this code. Any ideas would be great. The timing is right :cry:
Nov 17, 2007 at 8:05 PM
BMRFIXIT
  • 19,053 POSTS
[quote:2e8b4e5b48="Krash"]I just put a new engine in this truck and it will not start. I have replaced the cam position sensor and it still will not start. I pulled a P1391 code and the book dosent even show this code. Any ideas would be great. The timing is right :cry:[/quote:2e8b4e5b48]
try crank sensor
P1391 Intermittent Loss of CMP or CKP
Nov 17, 2007 at 11:18 PM
KRASH
  • 4 POSTS
Replaced both sensors. Should I disconnect the battery/ will this reset the computer?
Nov 18, 2007 at 7:20 AM
KRASH
  • 4 POSTS
What about the ring that is behind the camshaft gear?What is the chance this is bad? dont really want to pull this motor back down but, will if i have to.
Thanks
Nov 18, 2007 at 7:31 AM
BMRFIXIT
  • 19,053 POSTS
[quote:236c41a4d9="Krash"]What about the ring that is behind the camshaft gear?What is the chance this is bad? dont really want to pull this motor back down but, will if i have to.
Thanks[/quote:236c41a4d9]
did u make sure of the wiring
is it all pluged in and nothing get damage whille installing the engine
Nov 18, 2007 at 8:10 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a306f003d5="BMRFIXIT"][quote:a306f003d5="Krash"]What about the ring that is behind the camshaft gear?What is the chance this is bad? dont really want to pull this motor back down but, will if i have to.
Thanks[/quote:a306f003d5]
is it all pluged in and nothing get damage whille installing the engine[/quote:a306f003d5]
On the 4.7 u can remove the cam sensor and inspect the wheel
if loose or damage
tone wheel is located under CAM SENSOR IN FRONT ENGINE PASS SIDE
Nov 18, 2007 at 8:20 AM
KRASH
  • 4 POSTS
I am pretty sure everything is plugged in. I have removed th valve cover and can see the sensor and the wheel. The wheel is not loose and the plate is not bent, other than that i am not sure what kind of damage to look for.
Nov 18, 2007 at 9:11 AM
BMRFIXIT
  • 19,053 POSTS
[quote:37ee66da92="Krash"]I am pretty sure everything is plugged in. I have removed th valve cover and can see the sensor and the wheel. The wheel is not loose and the plate is not bent, other than that i am not sure what kind of damage to look for.[/quote:37ee66da92]
ok lets start over
truck no start after new engine install
do u have fuel pressure
do u have spark
do u have injector pulse
did u check the ASD relay
unplug and plug the BCM
because the code u have it may be only that the cam and crank sensor are not in sync
let me know
Nov 18, 2007 at 9:22 AM
