1999 Dodge Dakota vents
1999 DODGE DAKOTA
11,000 MILES • 6 CYL • 2WD • AUTOMATIC
DREESER1
i can not get any air to come out the vents. it will come out on the floor,the defrosters,but not the vents, also i had a new heater core put in a while back and now i only get warm air not hot air. how do i check to see if the vent doors are adjusted right?
Feb 24, 2010 at 7:47 PM
Actually, I think you are looking for a vacuum leak in this situation. Check under the dash for leaks. With the engine running, you may actually hear a hising sound from a leak.
Let me know what you find.
Feb 26, 2010 at 2:07 PM
DREESER1
i checked for a vacum leak i did not find one. i put my hand up in there and the vacume switch moves to various positions when i turn the selector switch . i did find a 2 inch hose for the side defrost was off but i can not get it back on, is there a hose that goes to the vent back under there also that could be off,i do not see how to get the dash out to get back in there,i have the face off but i cant get the top off ,i thought i have all the screws out but it will not move around at the emergancy brake release.is there a free assembl schematic diagram for the dash for a 1999 dodge dakota anywere ?
Feb 26, 2010 at 4:09 PM
