1999 Dodge Dakota engine misses while driving
1999 DODGE DAKOTA
88,881 MILES • 6 CYL • 2WD • AUTOMATIC
MSFIXIT2
Ill be driving theit starts cluging like it wants to go but does not .I just put a new starter in .would that have anthing to do with this ?
Jan 5, 2010 at 9:42 PM
Check and test the following below:
Oxygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Coil and Rotor
Jan 5, 2010 at 9:59 PM
