Tires and Wheels problem
1999 Dodge Dakota 6 cyl Two Wheel Drive Manual
My spare tire is mounted on an aluminum rim. It has developed a leak around the bead. I have removed the tire from the rim, cleaned the rim with a wire wheel, painted the rim with primer/filler, and clear coated over that to get a smooth surface. I cleaned the tire bead with soapy water, and dried it off. After remounting the tire, it still leaks. Is there anything else that I can do?
Jan 6, 2009 at 12:12 PM
