1999 Dodge Dakota
1999 DODGE DAKOTA
JOHNLONGA
Electrical problem
1999 Dodge Dakota 6 cyl Two Wheel Drive Automatic
dir signals continue to work after shutdown
Mar 11, 2009 at 6:07 PM
THETOOLMAN
  • 123 POSTS
Sounds like the electronic flasher relay may be stuck. The Flasher Relay is in the relay center. You may be able to remove the relay and then put it back and it work fine. However the contacts are probably burned and sticking. Just replace the relay.
Mar 26, 2009 at 9:25 PM
