1998 dodge dakota 5.2 litre 2wd, automatic trans. (44RE) recently purchased. Truck will not shift. It seems to start out in 2nd gear...if i put the selector in 1st gear, it will start off in 1st gear and wont shift untill i move the selector to "D" then it will shift once. The tranny does NOT slip. Check engine light was on...scanned and retrived po743, po753, po748 & po751. Cleared codes and drove truck over 20 miles under same conditions...po743 is the only returning code now.
Trans fluid looks brand new. I checked fuse #16 trans. control and it has only .4 volts going to it.
Any suggestions on repairs needed to correct?
Regards
BK
Regards
BK
Dec 24, 2009 at 1:05 AM
