1998 Dodge Dakota clutch question
1998 DODGE DAKOTA
Transmission problem
1998 Dodge Dakota Two Wheel Drive Manual
How do you bleed a hydralic clutch?
Oct 26, 2009 at 8:56 PM
CH112063
  • 1,320 POSTS
Same as brakes. Either with the bleeder or lines. With a helper starting at the master near the pedal and then at the slave cylinder. You can crack the hose fittings(loosen) and use if no bleeder or its frozen. I did gravity bleed them by loosening all of them and filling the resevoir as it lost fluid, this changes the fluid also. Pump pedal or just hold down to floor and bleed, until you start to feel some pressure.
Oct 28, 2009 at 8:16 PM
