1998 Dodge Dakota cant get driver window up
1998 DODGE DAKOTA
48,000 MILES • 6 CYL • 4WD • AUTOMATIC
#1MAC
ihave power windows and locks 3button swith is bad fall apart need to rise window its cold help!!!!
Feb 27, 2010 at 5:17 PM
IF the switch is bad, you have two choices, replace the switch or run 12 volts to the motor. THere are two wires on the motor. One is powered to lower the glass and the other to raise it.
You could use a jumper wire and a battery charger to raise it, but remember to disconnect the power when it is all the way up because it will burn up the motor.
Let me know if you have other quesitons.
Feb 27, 2010 at 9:33 PM
