Here is a guide to help you test the uses and the fuse panel locations and diagrams below.
Fuse Identification
1 - 30 Amp (Green) - A/C Or Heater Blower Motor
2 - 30 Amp (Circuit Breaker) - Power Windows
3 - 10 Amp (Red) (1992-93) - Back-Up Lights, A/C Electronic Cycling Switch 15 Amp (Lt Blue) (1994-96) - Back-Up Lights, Airbag Module, Overhead Console
4 - Not Used (1992) - 5 Amp (Tan) (1993-96) - ABS Brake System
5 - 20 Amp (Yellow) - Power Door Locks
6 - 15 Amp (Lt. Blue) - Horn, Tachometer
7 - 10 Amp (Red) - Anti-Lock Brake Module, Stoplights, Buzzers
8 - 20 Amp (Yellow) - Taillights, Park, Side Marker Lights, Clock & Radio Display Intensity, License & Panel Lights
9 - 15 Amp (Lt. Blue) - Cigarette Lighter
10 - 20 Amp (Yellow) - Windshield Washers & Wipers
11 - 20 Amp (Yellow) - Turn Signals, Rear Wheel Anti-Lock Module
12 - 10 Amp (Red) - Radio
13 - 4 Amp (Pink) - Cluster Lights, A/C & Heater Controls, Cigarette Lighter Light & Ash Receiver Light, Radio Lights & Overdrive Switch Light
14 - Not Used (1992-93) 15 Amp (Lt. Blue) (1994-96) - Airbag Module, Speedometer, Guages, Telltales
15 - 2 Amp (Gray) - Speed Control
16 - 5 Amp (Tan) (1992-93) - Gauges & Indicator Lights: Low Oil Light, Low Washer Light, Service Reminder Light, Transmission Oil Light, Brake Warning Light, Anti-Lock Brake Warning Light, Fuel Pacer Light, 4WD Indicator Light, Malfunction Indicator Light, Warning Buzzer, Overdrive Switch 5 Amp (Tan) (1994-96) - Transmission Oil Temperature Lamp, 4WD Lamp, Overdrive Module Seat Belt Warning Buzzer.
17 - (Blank)
18 - (Blank)
19 - (Blank)
20 - Not Used (1992-93) 25 Amp (Natural) (1994-96) - Fog Lamps and Off Road Lamps
21 - Turn Signal Flasher
22 - Time-Delay Relay
23 - Horn Relay
24 - Hazard Flasher
25 - Warning Buzzer
26 - Not Used (1992) - ABS Light Relay (1993-96)
Cheers
Sep 19, 2020 at 2:11 PM
(Merged)
