1997 Dodge Dakota 97 dakota 2wheel drive
1997 DODGE DAKOTA
JEHENSLEY
1997 Dodge Dakota V8 Two Wheel Drive Automatic
i have a dakota 97 3.9 magnum it starts but is rough. the truck will idle but will not take the gas fast if you go slow it will take it it also backfires but the firing order is right
Sep 30, 2010 at 1:39 PM
JDL
  • 16,098 POSTS
I'd use a gage and check fuel pressure. Any applicable codes? How long since a tune-up?
Sep 30, 2010 at 2:06 PM
JEHENSLEY
the fuel pressure has been checked and there are no codes on the computer it was running good but then it started messing up we put new plugs and wires the magnetic pickup was changed before the truck was messed up i was wondering if it could be the idle air control sensor? we covered one hole for the trottle body and it did not backfire if it could be is there a way to check it? is there a way to check a map sensor?
Oct 11, 2010 at 1:09 PM
JDL
  • 16,098 POSTS
What was the fuel pressure spec? When you wait this long to answer back, I get lost. Have a good day.
Oct 11, 2010 at 1:25 PM
