1996 Dodge Dakota a/c clutch bearing
1996 DODGE DAKOTA
CHESTER1028
Air Conditioning problem
1996 Dodge Dakota 6 cyl Four Wheel Drive Automatic
can i replace the a/c clutch bearing without pumping the system down? thank you all in advanced.
Oct 12, 2009 at 9:02 AM
CH112063
  • 1,320 POSTS
Yes. The finest compressor in the automotive business is almost completely serviceable, but the tools are needed.
I would be glad to walk you through it, it's not difficult, but you'll need to remove the belt, and clutch, as the front plate comes with bearing.
If you explain the noise and clearance you have I can give you instructions.
Oct 17, 2009 at 11:55 AM
