1995 Dodge Dakota Tach all over, lights dimming, what is go
1995 DODGE DAKOTA
ANTHONYAUTO
  • 20 POSTS
Electrical problem
1995 Dodge Dakota 6 cyl Two Wheel Drive Automatic
Does the pickup coil in the distributor or the crank sensor determine the engine speed displayed on the tachometer?
This vehicle is another one of those weird electrical freakazoids.
Vehicle brought in because it would quit running all of a sudden. Determined there was a fuel pump issue. Replaced fuel pump and ignition coil, and it runs. Took it for a test drive last night, and all of a sudden, the lights would dim, the tach and speedometer were all over the place but the engine wasn't changing speed it didn't seem, then it would try to die out. When it died, I'd turn it on 3 times to clear the computer, and then it'd start again. But not much further, lights would go dim, it'd start to buck, tack and speedo all over the place, but the engine wasn't revving up. Gimme some direction guys! :)
Sep 15, 2008 at 10:41 AM
ANTHONYAUTO
  • 20 POSTS
oh, a couple of more things. I would occassionally hear a little whine from the ECM. Like an electrical whine. And when I say the tach is all over, it will be idling... and it's jumping from 0 to 6000 while idling for example.
Sep 15, 2008 at 10:50 AM
2CARPRO JACK
  • 11,533 POSTS
Check your system voltages, light dimming usuallly means a bad connection, which will freak out the PCM
Sep 17, 2008 at 2:42 PM
