1995 Dodge Dakota Power booster cylander
1995 DODGE DAKOTA
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
MW1006
I believe my power booster needs to be replaced, do I need to take the dashboard apart to get to the four nuts and brake pedal pin or is there a better way to replace
Oct 6, 2008 at 11:48 AM
Hi:
You should be able to reach the bolts without taking anything apart. Keep in mind, the top ones are hard to get to, but patience will get you through it.
Also, are you sure the booster is bad?
Let me know if this helps or if you have any other questions.
Oct 21, 2008 at 7:01 PM
