1995 Dodge Dakota ADJUSTMENT
1995 DODGE DAKOTA
THE RICKG
Brakes problem
1995 Dodge Dakota V8 Two Wheel Drive Automatic
WHAT KEEPS REAR BRAKES IN ADJUSTMENT ?
Oct 15, 2009 at 12:18 PM
SERVICE WRITER
  • 9,123 POSTS
There is an adjuster wheel.
Release parking brakes fully, if applied. Be sure there is slack in the cables.
Raise vehicle so rear wheels are free to turn.
Remove rubber plugs from access holes in rear brake support plates.
Insert Drum Brake Adjusting Tool through access hole and engage it in adjuster screw star wheel. Turn star wheel counterclockwise (move tool upward) until a slight drag is felt when road wheel is rotated.
Insert a thin screwdriver or length of welding rod into support plate access hole and push adjuster lever out of engagement with star wheel. Do not bend the lever or distort the lever spring.
Hold adjuster lever away from star wheel. Then back off star wheel until shoe drag on drum is eliminated.
Repeat above adjustment at the opposite wheel. Be sure adjustment is equal.
Install access hole plugs in support plate.
Adjust the parking brake after wheel brake adjustment.
Make final adjustment. Drive vehicle and make one forward stop followed by one reverse stop. Repeat procedure 8-10 times to actuate adjuster mechanism and equalize adjustment. Bring vehicle to complete standstill at each stop. Incomplete, rolling stops will not activate the automatic adjusters.
I prefer to pull the drum, remove the edge on it and adjust them after cleaning them with brake clean and lubing.
https://www.2carpros.com/how_to/rear_brake_shoes.htm
Oct 15, 2009 at 12:53 PM
