1994 Dodge Dakota vibration damper run out
1994 DODGE DAKOTA
200,000 MILES • V8 • 4WD • AUTOMATIC
TRG
  • 11 POSTS
Is any amount of run out or wobble acceptable? All the other pulleys have no visible wobble but there's about a 1/16 in. movement visible at the crankshaft pulley.
Mar 22, 2008 at 12:34 PM
MASTERTECHTIM
  • 4,750 POSTS
are you having problems with belts coming off or wearing out too often? there is no spec for run out but obviously you should have none. the balancer is mounted in rubber and over time you will get some variances, if its causing you some problem or it seems to get worse then replace it.
Mar 22, 2008 at 7:18 PM
TRG
  • 11 POSTS
I just bought the truck about a month ago. It had a new belt installed. My main worry is will this damage my crankshaft bearings? Or cause a timing cover oil seal leak?
Mar 22, 2008 at 9:21 PM
MERLIN2021
  • 17,250 POSTS
If the balancer is solid, but moves in and out with the engine running, it's the thrust bearing which is one of the mains...
Mar 23, 2008 at 8:36 AM
