Code 45 and 37 changed all the sensors on the tranny nutral,speed / Just bought the truck less than 48 hrs ago... I am noticing when driving it will shift all three gears fine but not go into fourth. I want to know what is causing this.
The o/d switch on the dash board is not working either and I checked it is getting power from the fuse panel it wont turn on or off. The vehicle is running as if overdrive is off constant and I need it to be on constant. Does anyone know how to fix this and if so please let me know.
All fuses good. Previous owner did some shabby electrical hook up to radio and radio is not working at all I am wondering if these two problems are similar ... The radio is showing power at the fuse block but not at the radio. .. Could he have shorted out the PCM? please help
May 8, 2010 at 4:47 PM
