First, the book tell us it can only be done with a scan tool. Take a look:
1991 Dodge or Ram Truck Dakota 2WD V8-318 5.2L
Emission Maintenance Reminder Light (EMR) Reset
Vehicle Powertrain Management Emission Control Systems Emissions Maintenance Light Service and Repair Procedures Emission Maintenance Reminder Light (EMR) Reset
EMISSION MAINTENANCE REMINDER LIGHT (EMR) RESET
This output device is located in the instrument panel, and its purpose is to inform the driver that the vehicle requires scheduled maintenance for certain emission system components. The Single Board Engine Controller (SBEC) illuminates this lamp at certain mileage intervals. The controller keeps track of the vehicle mileage by monitoring the vehicle distance (speed) sensor. The EMR Lamp illuminates at 60,000 mi, 82,500 mi, and 120,000 mi.
The manufacturer recommends performing the following procedures at these intervals:
60,000 miles
Replace EGR Valve
Replace EGR Tube (if equipped)
Clean EGR passage
Replace PCV Valve
82,500 miles
Replace Oxygen Sensor
120,000 miles
Replace EGR Valve
Clean EGR passage
Replace PCV Valve
RESET PROCEDURE
The Emissions Maintenance Reminder (EMR) light can ONLY be reset through the use of a SCAN TOOL. If the engine controller is replaced, the current vehicle mileage needs to be entered into the EMR memory of the new controller. For more instructions on the use of a scan tool, refer to Computers and Control Systems/Testing and Inspection/Procedures.
________________________________________
If the dealer has the adapter for this vehicle, that is the easiest way to do it. Do they have the correct adapter?
The only other way I have ever had it reset was by disconnecting the battery. The computer on this vehicle isn't extremely complex. There is a relearn process, but it does it by itself and takes very little time. You may notice a rough idle or other minor things, but it will go away by itself after a few short drives.
Let me know if you have other questions or need help.
Aug 28, 2020 at 9:24 AM
(Merged)
