1994 Dodge Dakota lower radiator
1994 DODGE DAKOTA
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
IRISHOB
How do you disconnect the lower radiator hoses? There is a nut on the radiator. I disconnected it but it wouldn't pull apart. How do you disconnect the two transmission hoses into the radiation. They have some kind of compression hose into the radiator and though I have taken the nut off on the radiator side, the hose will not pull off.
Sep 28, 2010 at 5:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
radiator hose is just clamped on to the radiator at the end of the hose, just remove the clamp and then pull the hose off.
Sep 28, 2010 at 6:14 PM
