The truck seems to run fine till it I reach highway speeds then starts to stall after it starts to stall it stalls in all gears after searching mutiple fourms i did the stupid thing and started shotgunning because it wasn't throwing any codes so so far I have replaced the following a few are unrelated I think but mentined anyway just in case and tested map sensor responded as it should
water pump
hoses
thermostat
coollent temp sensor
egr valve
pcv valve
plugs
wires
cap
rotor bug
coil
o2 sensor
tps
From what i read im down to pick up coi/distrubitor,l asd relay, or fuel pump
am I right in thinking this, and is there a way to test the above. I am running out of shells
water pump
hoses
thermostat
egr valve
pcv valve
plugs
wires
cap
rotor bug
coil
o2 sensor
tps
Sep 13, 2010 at 11:18 AM
